ACU-T: 6105 / SL 2441 - Single Particle Sedimentation – Effect of Lift and Torque
Prerequisites
Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction. To run this simulation, you will need access to a licensed version of SimLab and AcuSolve.
This tutorial demonstrates the set up of a flow solution in SimLab. Before you begin, download the CAD geometry.
You will need an internet connection to watch the video tutorials and download the files.
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
