Inspire Family Unit Draw
A summary of the Altair Units (AUs) drawn by application.
The Inspire Family of applications provides integrated solutions for industrial design, rendering, concept design, design simulation, as well as manufacturing feasibility and process simulation.
| Application | AUs | License Feature(s) | Description |
| Inspire Render | 2 | InspireRender | Full-featured concept design rendering environment created specifically for industrial and product designers. |
| Inspire Studio | 5 | InspireStudio | Full-featured concept design modelling environment created specifically for industrial and product designers. |
| Inspire | 15 | Inspire InspireGeometry |
Easy-to-use concept environment which empowers design engineers to leverage simulation and optimization throughout the design process. Including generative design, structural analysis, motion simulation, casting and stamping feasibility. |
| 15 | InspireOSSolver | License feature is required when OptiStruct is used for structural analysis. | |
| 15 | InspirePrint3D | Set up model for Print3D. It takes 30 AUs and check out InspireMfgSolver license feature to run Solver. |
| 25 | HyperStudy | For Design Explorer integrated in Inspire. | |
| 30 | Inspire | Enables SimSolid as structural analysis solver. | |
| 30 | InspireFluid | Assess fluid and thermal behavior early for faster, more informed product design cycles. | |
| 30 | InspireFluidsSolver | Enables the InspireFluids solver to be launched. | |
| 30 | InspireMfgSolver | Full-featured additive manufacturing module with support
generation/slicing, process simulation, for both SLM and Binder
Sinter processes. This feature is used to run the Print3D solver. |
| Sulis | 15 | Sulis | A design for additive manufacturing tool enabling fast geometry creation for complex lattice structures and fluid flow channels. |
| Inspire Form | 15 | InspireForm | Invokes the Feasibility tab. A virtual environment stamping analysis based on part or tooling geometry. Thinning and formability issues, as well as estimated blank shape and maximize material utilization via blank fitting and nesting utilities can be evaluated. Forming feasibility via one-step solver. |
| 30 | InspireFormIncr | Invokes the Tryout tab. A virtual environment stamping analysis based on part or tooling geometry. Thinning and formability issues, as well as estimated blank shape and maximize material utilization via blank fitting and nesting utilities can be evaluated. Forming feasibility via one-step solver. | |
| 15 | InspireOSSolver | License feature is required when OptiStruct is used for feasibility analysis. | |
| 30 | InspireRadiossSolver | Allows you to run incremental analysis using Radioss solver. | |
| Inspire Cast | 30 | InspireCast, InspireMfgSolver | A casting process simulation software that allows you to enhance and optimize their manufactured components with efficient mold design and process development. |
| Inspire Extrude Metal | 30 | InspireExtrude, InspireMfgSolver | Metal extrusion simulation solution. |
| 15 | InspireOSSolver | License feature is required as OptiStruct is used for structural analysis. | |
| Inspire Extrude Polymer | 30 | InspireExtrude, InspireMfgSolver | Polymer extrusion simulation solution. |
| Inspire Friction Stir Welding | 30 | InspireExtrude, InspireMfgSolver | Friction stir welding solution |
| Inspire Mold | 30 | InspireMold, InspireMfgSolver | Injection molding simulation |
| Inspire Resin Transfer Molding | 30 | InspireExtrude, InspireMfgSolver | Resin transfer molding simulation |
| Inspire PolyFoam | 50 | InspirePolyFoam | Polyurethane foam simulation |
| 100 | InspirePolyFoamSolver |
