Altair HyperMesh
Enhancements
- SN Curve Plot Functionality
- Plot functionality exposed in the Model Browser material view for the MATFAT card defined with single/multiple SN curve definition.
- Static Failure
- The MATFAT and FATPARM cards are enhanced to input static failure definition for single/multiple curves in continuation to the SN line.
- Moved Non-structural Mass and Non-structural Material Damping Cards
- These cards are migrated from Group to Solver Mass entity.
- NSM1/NSM/NSML1/NSML and NSGE/NSGE1 bulk cards are now mapped to Solver Mass entity.
- NSMADD bulk data card is now mapped to Solver Mass entity.
- Multiple Failure Criteria Definition
- Multiple different failure criteria can be defined on a single MATF bulk card entry.
- New MATTVE Material Card
- A new material card MATTVE is added to define temperature-dependent nonlinear viscoelastic material.
- Model Checker
- Free 1D element nodes check is now available in the model checker.
- DENSITY Option in I/O Options
- A new DENSITY option is added in RTHRESH, THRESH, TOP, RTOP I/O cards.
- PBUSH and PBSUHT Cards
- The PBUSH and PBSUHT cards are enhanced to define KMAG and ANGLE continuation lines.
- SYSSETTING Card
- The SYSSETTING card is enhanced with a MULTIPLEOUTPUT option to define multiple formats of the same output request.
Resolved Issues
- The JOINTG element type INLINE is no longer imported as INLIORIE.
- Input files with DRAPE table no longer results in a segmentation error.
- The PCONT and PSOLID cards in large field format now export correctly.
- The MPF option is now available in the ERP card.
- Component organization is no longer lost while importing input with includes created in previous releases.
- In the Beam Orient tool, orientation in displacement is streamlined.
- System selection and toggle basic/displacement to define orientation vector are removed from the microdialog. A direct option to enter components in the displacement system is available. A vector tool with user system selection to enter orientation vector is always in basic.
- The OFFT key assigned to elements when assigning orientation in the displacement system no longer has issues.
