Altair HyperMesh
New Features
- Support of the new Radioss 2023 profile
- Joint Creation Tool
- This new tool enables the automatic creation of KJOINT2 and CYL_JOINT elements, as well as the rigid attachments of the joint to the selected connected parts
- The tool is accessible from the Model Ribbon:
- Time Step Mass in Mass Summary Tool
- A new option in the Mass Summary Tool enable the calculation of the solver numerical added mass due to the elemental time step
- From the guide bar, click and select the Consider Time Step Mass checkbox.
- The corresponding Time Step Mass column and total values are then display in the UI:
Enhancements
- New Starter Keywords supported
- /EOS/TABULATED
- /FAIL/INIEVO
- /FAIL/SYAZWAN
- /FAIL/TAB2
- /SENSOR/TEMP
- /TRANSFORM/POSITION
- New Engine Keywords supported
- Multiple new output options supported in /H3D/ELEM
- Multiple new output options supported in /H3D/NODA
- Multiple new output options supported in /H3D/SHELL
- Multiple new output options supported in /H3D/SOLID
- Updated Starter Keywords as per Radioss 2023 manual
- /BEAM: 3rd node made optional
- /INTER/TYPE8: New attribute Fn_last and Ft_last
- /INTER/TYPE18: New attribute Igap
- /MAT/LAW62: New attribute Form and Poisson ratios
- /MAT/LAW88: New attribute value Tension=-2
- /PROP/TYPE14: New attribute Iale
- /RBODY: New attribute Ifail
- /SENSOR/DIST: New attribute Tmin and Dflag
- Support on nested SUBMODELs
- Elements Entity Editor
- The description of the Elements Entity Editor is updated and aligned to the solver manual description
- Rigid Body Manager
- The Rigid Body Manager is replaced by the new Rigid Body creation controller
Resolved Issues
- Correction in reading the Engine keywords /DT/AMS
- Correction of the dynamic graphical update of /RBODY when modifying the node set in case of a formula set
- Correction in reading /VISC/PRONY when the keyword is encrypted
- Correction in reading and exporting Area and Inertia attributes in /PROP/BEAM when Beamsection is Unresolved
- In some cases, /GRNOD/NODE referred into /INTER keyword was exported as an empty /GRNOD/GENE set. This issue is now corrected.
- CYL_JOINT is now implemented correctly.
