Altair HyperView
New Features
Read new Element Type
Read MSC NASTRAN and NX NASTRAN CPYRAM Elements.
SOL 400
Support SUBCASE, STEP and SUBSTEP Organization, for OP2 and HDF5 Formats.
SOL 146 (Gust Response)
Split Random Gust Response’s PSD, RMS Cumulative RMS (CRMS), Positive Zero Crossing (N0) and Auto-Correlation Function in different Load Cases.
Random Response
Split PSD, RMS Cumulative RMS (CRMS), Positive Zero Crossing (N0) and Auto-Correlation Function in different Load Cases.
Read more NVH Results
Read Sound Pressure, RMS Sound Pressure, Sound Pressure in dB and Sound Pressure in dBa, from OP2 and HDF5 Files.
Read Equivalent Radiated Power (ERP), from OP2 and HDF5 Files.
Read Vibration Intensity (VINTENSITY), from OP2 and HDF5 Files.
Enhancements
Read Random Gust Response’s Positive Zero Crossing (N0) and Auto-Correlation Function (AUTO), for OP2 and HDF5 Formats.
Random Response
Read Positive Zero Crossing (N0) and Auto-Correlation Function (AUTO), for OP2 and HDF5 Formats.
GPSTRESS and GPSTRAIN
Read GPSTRESS and GPSTRAIN Results for 2D Elements, from OP2 and HDF5 Files.
Known Issues
The following known issues will be addressed in a future release as we continuously improve the software:
  • Rad Heat Transfer results, for HDF5 Files.
Resolved Issues
  • Correct Elemental Results’ Transformation for OptiStruct’s, MSC NASTRAN’s and NX NASTRAN’s CPENTA Element.
  • Read PSD and RMS Results for Velocity and Acceleration Results.
  • Read RMS Results for Beam Elements.
  • Read Stress Results when < PARAM, OMID, YES > is used.
  • Read correct Composite Material Results, for Frequency Response, from OP2 Files.
