Define Faceting Parameters
Each geometry part has a Faceting property.
                From the Property Editor, define Faceting parameters.
                - Enable the Override check box to recreate the facets.
- Select the Resolution.
- Optional:
                Manually control all parameters.
                - For Resolution, select Custom.
- Enter a value for Chordal Deviation to define the maximum deviation from the underlying curve.
- Enter a value for Angular Deviation to define the maximum difference in normals between neighboring elements.
- Enter a value for Average Element Size to define the element size.
