Automatic Report Generation Examples
Use hwCFDReport to create a .pptx or .pdf report with user defined visualization.
Create a Simple Input File
To create a simple input file with a cover page and summary, navigate to the simulation results folder, and create a file named report.img with the following contents:
COMMAND, followed by curly
                braces {} with options specified inside the braces. The simulation
                data to summarize is specified with the DATASET{}
                command.DATASET{
     resultFile                 = "uFX_fullData\uFX_output.case"
     summary_file               = " uFX_summary.txt"
     summary_in_report          = on
REPORT("Run summary"){
    report_type                 = run_summary
    format                      = pptx
}>> hwcfdReport –img report.imgAdd Images
IMAGE{} command to tell the utility to create and display an
                image. In the command options, specify which parts are to be shown and the views
                from which the image is to be rendered. In this example, we define two views: front
                and left.IMAGE("Car_view"){
    parts                      = {"Car"}
    views                      = {"front","left"}
    image_type                 = static
}PART{} command. This particular command instance is named
                Car and is referenced above with this name. A PART{} command
                includes all boundaries and default visualization settings. These are optional and
                can be customized as seen
                below:PART("Car"){
     show_boundary_names       = {"_all"}
     display_type              = solid
     color_type                = constant
     constant_color            = "white"
}|  Figure 1. |  Figure 2. |
Results Visualization Tools
The advanced options enable you to unlock more colorful possibilities. Visualization
                mainstays such as Contours, Cut-planes, Iso-surfaces, and Streamlines have dedicated
                commands. Two- dimensional plots such as Line-plots and Bar-charts can also be
                created. All these commands can be further customized using the
                    VARIABLE{} command that makes these commands more powerful and
                portable across multiple simulations. Last but not the least, two simulation results
                can be used to create a report that renders images side by side for a quick spot the
                difference comparison.
Surface Contours
color_type from constant to contour. This changes the
                coloring of the car model from a constant color to a surface contour. We also
                specify the contour function which controls the coloring of the contour, in this
                example time_avg_pressure_coefficient. This is followed by more
                settings that control the legend on the right-hand corner in the
                    plot.IMAGE("Surface Cp"){
    parts                      = {"Surface Cp"}
    views                      = {"front_top_left"}
    image_type                 = static
PART("Surface Cp"){
     solid_display_type        = smooth
     color_type                = contour
     contour_function          = time_avg_pressure_coefficient
     legend_display                                = on
     legend_min                = -0.5
     legend_max                =  0.5
Figure 3.
Cut Planes
y = 0 is
                defined. The instantaneous velocity magnitude, inst_velocity_mag,
                is used to color the plane and the size of the plane is controlled by the inputs:
                    x_min, x_max, and z_max.car_length and
                        car_height are needed for the command to
                    work.IMAGE("Cut plane y inst. vel"){
    cut_planes                 = {"y cut vel_inst"}
    parts                      = {"Full vehicle - white"}
    views                      = {"left"}
    clip_parts                 = off
CUT_PLANE("y cut vel_inst"){
     normal_direction          = y
     cut_location              = 0.0
     contour_function          = total_pressure_coefficient
     legend_display            = on
     legend_min                = 0.0
     legend_max                = 45.0
     x_min                     = -0.78 - car_length/4.0
     x_max                     = 3.29 + car_length
     z_max 		       = 1.3 + 0.5*car_height
Figure 4.
Variables
variable_name, and an expression associated
                with it. The expression can be a constant, another variable, or a mathematical
                expression containing more variables. The following variables,
                    car_length and car_height need to be defined
                to get the CUT_Plane{} in the previous section to work
                correctly.VARIABLE{
	variable_name  			= car_length
	expression 				= 4.07
VARIABLE{
	variable_name  			= car_height
	expression 				= 1.317
}Iso-Surfaces
ISO_SURFACE{} command. In this
                example, the time averaged pressure coefficient,
                    time_avg_pressure_coefficient, is used to create the
                iso-surface which is then colored with a constant color, blue for
                    time_avg_pressure_coefficient=-0.3 and red for
                    time_avg_pressure_coefficient=0.5.
                    IMAGE("Cp Iso""){
iso_surfaces	= {"Cp = -0.3”,” Cp = 0.5"”}
views	= {"left"}
image_type	= static
ISO_SURFACE("Cp = -0.3"){
iso_function	= time_avg_pressure_coeffient
iso_value	= -0.3
constant_color            = blue
ISO_SURFACE("Cp = 0.5"){
iso_value	= 0.5
constant_color            = red
Figure 5.
Line Plots
data_file input. The data in the
                        ASCII file is organized
                into rows and columns. Specify the column numbers in the x_column
                and y_column fields to get a line
                    plot.LINE_PLOT("Instantaneous drag"){
    data_source                = "file"
    data_file                  = "./uFX_coefficientsData/uFX_coefficients_Inst.txt"
    num_header_rows            = 11
    x_column                   = 1
    y_columns                  = {2}
    x_label                    = "Time (s)"
    y_label                    = "Coefficients"
    title                      = "Instantaneous Drag"
    legend_labels              = "C_d"
    show_legend                = on
    show_grid                  = on
Figure 6.
