ACU-T: 4002 Sloshing of Water in a Tank
Prerequisites
This tutorial provides instructions for running a transient simulation of a two-phase flow in a rectangular tank using the level set model. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 Basic Flow Set Up, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Since the HyperMesh CFD database (.hm file) contains meshed geometry, this tutorial does not include steps related to geometry import and mesh generation.
Problem Description
The problem to be solved is shown schematically in the figure below. It consists of a partially filled water tank and from time t=0, water inside the tank is subjected to a sinusoidal varying body force along x-direction and constant gravity along y-direction.
The body force in the x-direction is given by the expression:
- Α = Amplitude of oscillation = -0.06 m
- ω = Frequency of oscillation = = 3.6 rad/sec
- T = Time period of oscillation = 1.74 sec
- φ = Phase difference = 0
Validate the Geometry
Figure 3.
Set Up the Problem
Assign Material Properties
Set the Body Force
Compile the Body Force UDF
                For Windows:
                For Linux:
Define Nodal Initial Conditions
Define Nodal Outputs
Run AcuSolve
Post-Process the Results with HM-CFD Post
Summary
In this tutorial, you successfully learned how to set up and solve a transient multiphase flow problem involving water sloshing in a tank using HyperMesh CFD and AcuSolve. You also learned how to create a multiphase model using the Level Set method and specify the body force using a user-defined function and then compile the UDF. Once the solution was computed, you post-processed the results using the Post ribbon where you generated an animation of the water sloshing in the tank.
 on the
 on the
 and enter the following
                    values.
                    values.
 to execute
 to execute
 to execute the command and remain in the
                        tool.
                        tool.
 in the
 in the
 and set the coordinates to (0.60, 0.12,
                        0.10).
                        0.10).
 to add a variable then select
 to refresh the range.
 to refresh the range. , and set the Colormap Name to
 at the bottom of the
 on the toolbar.
 on the toolbar. on the toolbar then drag over the area you
                            want to record.
                            want to record. to start recording and the same button to
                            stop recording.
                            stop recording.
