HMCFD-T: 1020 Wrapping Using the Template Manager
Before you begin, copy the file(s) used in this
                                tutorial to your working directory.
        Create Groups
- Open the Wrapping_Example_Engine.hm file.
 - Make sure the entity selector in the modeling window is set to Parts.
                Select the three bolts parts highlighted in the figure below.
Figure 1. -
                Right-click and select Find and Isolate > Matching Parts.
                The tool searches for all bolts matching the features of the highlighted parts and isolates them on the screen.
Figure 2. - Left-click and drag to select all the bolts on the screen then right-click and select Create Group.
 - Label the group Misc then click Create.
                Right-click and select Reverse (R) to display all the
                    parts besides the bolts.
Figure 3. - Left-click and drag to select all the parts on the screen then right-click and select Create Group.
 - Label the group ToWrap then click Create.
Create the Template
                Click the arrow next to the Home tool set, then
                    select Template Manager.
Figure 4. - Select Operation from the list of categories in the Template Manager dialog.
                Click
 to add an operation.
Figure 5. -
                Double-click in the Operation column and select
                        Tessellation.
Figure 6. -
                Click
 in the Definition column. Ensure that the Unmeshed
                    surface meshing method is set to Faceting with a size
                    definition set to Normal.
                Click
 to add another operation.
             - Double-click in the Operation column and select Cap.
 - Under the Selection Mode column, select By user groups.
                Under the User Group Selection column, select
                    ToWrap.
Figure 7. -
                Click
 and enter a maximum width of
                        100.
Figure 8. -
                Click
             - Double-click in the Operation column and select Wrap.
                    ToWrap.
Figure 9. -
                Click
 and enter a value of 20 for
                    the Average element size.
Figure 10. -
                Click
             - Double-click in the Operation column and select Re-mesh.
                    ToWrap.
Figure 11. -
                Click
                    the Average size.
Figure 12. -
                Click
             - Double-click in the Operation column and select Fix Surface Mesh Quality.
                    ToWrap.
Figure 13. -
                Click
 and enable Degenerated element
                        cleanup, Duplicate element cleanup,
                        Aspect ratio cleanup, and Intersection
                        cleanup.
Figure 14. -
                Click
             - Double-click in the Operation column and select Delete.
                    Misc.
Figure 15. - At the bottom of the dialog, enable Run operations and Validation.
                Click
 next to Validation and set the Sliver Surface Threshold to
                        0.0001.
Figure 16. - Click Run to execute the template.
Save the Template
                Click
                    dialog.
             - Enter a name for the file.
 - Click Save.
 - Close the Template Manager.
                Observe that the Validate tool on the Geometry ribbon has a blue check mark,
                    which indicates that the validation was successful.
Figure 17.
