::GetNextAvailableVarnameAndLabel
This command will be used to get the next available (not already used) pair of varname and label values for a given base name and base label within a given system.
::model::GetNextAvailableVarnameAndLabel argV argL argParent argBaseV argBaseL
MotionView Tcl
- argV
- This is a variable that will be assigned the value of the next available varname.
- argL
- This is a variable that will be assigned the value of the next available label.
- argParent
- This is the system context in which you need to look for the unused next available varname and label pair.
- argBaseV
- This is the varname that you want to use as the base for the next available varname.
- argBaseL
- This is the label that you want to use as the base for the next available label.
set var_name ""
set label_name ""
set parent "MODEL"
set base_var "p_"
set base_label "Point "
::model::GetNextAvailableVarnameAndLabel var_name label_name $parent $base_var $base_label
puts $var_name
puts $label_nameErrors
On successful execution of the command, the two variables will be filled with new varname and label and that label is returned.
