amfIMarker GetTracklineThickness
Gets the thickness of the trace line drawn for a marker.
marker_handle GetTracklineThickness
Returns the thickness of the marker’s trace line. The return value will be an integer corresponding to a standard line thickness setting in HG.
marker_handle GetTracklineThicknessError
3 = HW_InvalidHandle
