ctx::selection
Controls the selections of the active context.
ctx::selection method ?selection_name? ?option value option value...?
ContextDescription
Controls the selections of the active context and sets the attributes of the specified selection. This command is only valid for the HyperMesh client.
Methods
- active
- Returns the name of the active selection.
- add selection_name option
- Adds entities to the specified selection. For the list of available selection options, please refer to the *createmark documentation page.
- clear ?selection_name?
- Clears the selection. If selection name is not provided, the active selection is used by default.
- copyfrom ?selection_name?
- Copies the content of a mark to the selection. If selection name is not provided, the active selection is used by default.
- copyto ?selection_name? option value
- Copies the content of the selection to a mark. Currently, the only supported option is -mark. The value is the ID of mark to copy the selection to. If selection name is not provided, the active selection is used by default.
- count ?selection_name?
- Returns the number of entities in the selection. If selection name is not provided, the active selection is used by default.
- get ?selection_name? option
- Returns the current value of the given option. If selection
                            default. The available options are:- -type
- -types
- -ordered
- -single
- -highlight
- ids ?selection_name?
- Returns the list of IDs of the entities in the selection. If selection name is not provided, the active selection is used by default.
- names
- Returns list of selection names available in the active context.
- remove selection_name option
- Removes entities to the specified selection. For the list of available selection options, please refer to the *createmark documentation page.
- set ?selection_name? option1 value1 option2 value2 ... optionN valueN
- Updates the value of the specified option to the provided value.
                            Multiple option-value pairs can be defined. If selection name is not
                            provided, the active selection is used by default. The available options
                            are: - -type
- -types
- -ordered
- -single
- -highlight
Examples
set active_sel [ ctx::selection active ]
ctx::selection add $active_sel allctx::selection get -typectx::selection set -types {elements components} -single 1Errors
   # Handle error
}Version History
2022.1
