hwIAnimator GetEndTime
Gets the end time in seconds.
hwIAnimator_handle GetEndTime
HyperView Tcl Query
This command returns the end time in seconds.
Error
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Tests if the animator is at the model step.
Gets the current animator's bounce state.
Gets the current frame index.
Gets the current animation step index.
Gets the current time in seconds.
Gets the end frame index.
Gets the current animator's maximum time.
Gets the current animator's minimum time.
Gets the current mode (or type) of the current animator.
Gets the number of frames to be interpolated.
Gets the number of animation steps.
Returns the start frame of the animator.
Gets the start time in seconds.
Advances the animator to the next frame. If the animator is at the last frame, Next wraps to the first frame.
Advances the animator to the previous frame. If the animator is at the first frame, Previous wraps to the last frame.
Sets the current animator's bounce state.
Sets the current frame index.
Sets the current animation step index.
Sets the current time.
Sets the end time.
Sets the number of frames to be interpolated.
Sets the start frame of the animator.
Sets the start time.
Sets the current animator's use bitmap flag.
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
