hwIH3DExportOptions GetMaxCompressionError
Queries the maximum margin of error allowable during compression.
hwIH3DExportOptions_handle GetMaxCompressionError
Tcl Query
Returns a number between zero and one, representing the ratio between the allowable absolute error and the maximum difference between values in the set.
Compression is comprised of two processes: lossy and non-lossy. To produce lossless compression, turn compression on and set the allowable error to zero.
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetMaxCompressionErrorError
None.
