hwIPage SetAnimationFrameRateTracking
Enables the animation frame rate tracker.
hwIPage_handle SetAnimationFrameRatesTracking enable
Tcl Modify
This command determines whether the animation frame rate tracker is enabled.
- enable
            - True
- If you want the animation frame rate tracker to be on.
- false
- If you do not want the frame rate tracker on.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 SetAnimationFrameRatesTracking true;Error
Keywords
Tcl
Animation
Modify
