hwIPreferenceManager RegisterPreferenceFile
Adds the preference file to the internal list of preference files.
hwIPreferenceManager_handle RegisterPreferenceFile menuName filePath isDefault
Tcl
This command reads the preference file to the internal list of preference files.
- menuName
- The name that you want to call the preference file in the Preference menu.
- filePath
- The filepath of the desired file (within “” or {}, if there are spaces in the filepath).
- isDefault
- A true or false value.- true
- If you want the preference file to be the default preference file.
- false
- If you do not want the preference file to be set as the default.
hwi GetSessionHandle sess;
sess GetPreferenceManagerHandle pref;
pref RegisterPreferenceFile MyFile.mvw c:/MyFile.mvw false;Error
Keywords
Tcl
Preference Manager
