hwITemplex GetNumberOfFunctionParameters
Determines the number of required parameters for a specified math function.
hwITemplex_handle GetNumberOfFunctionParameters funcname
Tcl Query
- funcname
- The function for which the number of required parameters is desired.
mySessionName GetProjectHandle myProjectName
myProjectName GetTemplexHandle myTemplexName
myTemplexName GetNumberOfFunctionParameters frfmagErrors
None.
