hwIXMLFile SetFilename
Sets the current XML file.
hwIXMLFile_handle SetFilename filename
Tcl Modify
This command sets the current XML file.
- filename
- The filepath of the file that you want to set as the XML file.
hwi GetSessionHandle sess;
sess GetXMLFileHandle XML "c:/Documents and Settings/user/My Documents/hwsettings.xml";
XML SetFilename "c:/Documents and Settings/muriellesmith/My Documents/test.xml";Error
Returns success (0) or an error code.
Keywords
Tcl
XML
Query
