plt3DIChart GetVisibility
Gets the chart’s visibility state.
plt3DIChart_handle GetVisibility
Tcl Query
- True
- The chart’s shadow is visible.
- False
- The chart’s shadow is not visible.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets a handle to a pltIVector interface for the specified curve.
Returns the chart’s highlight state.
Gets the number of points on the chart.
Returns the chart’s shadow color index.
Gets the shadow plane of the chart.
Returns the shadow’s visibility state.
Gets the symbol style of the chart.
Sets the chart’s highlight state.
Sets the chart’s shadow color index.
Sets the shadow plane of the chart.
Sets the auto shadow visibility state.
Sets the symbol style of the chart.
Sets the auto chart visibility state.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
