plt3DINote GetPoint
Gets an attachment expression for the note.
plt3DINote_handle GetPoint axis
Tcl Query
Returns the attachment expression of the note.
- axis
- The axis (x, y, or z).
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets the text alignment for the note.
Gets an attachment object for the note.
Finds whether the note is placed automatically.
Gets the text color of the note.
Gets a handle to an hwIFont interface for the font of the note.
Finds the note’s I position.
Gets the note’s index.
Finds the note’s J position.
Gets the title of the note.
Finds the size of the aperture.
Gets the position of a note in the plot client.
Gets the unevaluated text of the note.
Gets whether the note is on (visible) or not.
Sets the text alignment for the note.
Sets the attachment method for the note.
Sets whether the note is placed automatically.
Sets the border thickness of the note.
Sets the text color of the note.
Sets the note’s I position.
Sets the note’s J position.
Sets the title of the note.
Sets the attachment expression of the note.
Sets the user-defined position of a note in HyperGraph 3D, or sets the fixed position of a note in the GUI.
Sets the unevaluated text of the note.
Sets whether the note is visible or not.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
