plt3DIPlane SetD
Sets the current drag location for the plane.
plt3DIPlane_handle SetD location
Tcl Modify
- location
- The real value of the current drag location for the plane along its normal. The value must be between GetDMin and GetDMax.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName GetPlaneHandle myPlaneName [myPlotName AddPlane]
myPlaneName SetD 10.0Errors
Success (0) or an error code.
