pltICursor Find
Sets the cursor’s position to find the closest value to the input arguments.
pulICursor_handle Find args
Tcl Query
- args
- A list of coordinates to match. The coordinates must begin with the coordinate axis (“x”, “y”, or “z”), followed by the coordinate number (“0123456789.+-“) with a space between the two values. The list must be within “”. If the list only has one coordinate, such as “x 9”, the command finds the first point with a value above the input coordinate. If the list has two of the coordinates, such as “x 3 x 2”, it finds the closet point on the curve to the input coordinates.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetCurveHandle c1 1;
c1 GetCursorHandle cur 1;
cur Find "x2 y3";
cur GetX;
cur GetY;Errors
Success (true) or an error message is returned.
Keywords
Tcl
Cursor
Query
