pltIDataAttribute GetLabel
Gets the label for a data attribute.
pltIDataAttribute_handle GetLabel
Tcl Query
Returns the data attribute label.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets the value for a data attribute.
Returns the type of data attribute.
Gets the variable name for a data attribute.
Sets the label for a data attribute.
Sets the value for a data attribute.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
