pltILegend GetPosition
Gets the relative position of the legend.
pltILegend_handle GetPosition
Tcl Query
A compound list containing the relative horizontal and vertical positions of the legend.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets the border thickness of the legend.
Returns the integer value of the legend border color.
Gets the legend’s context menu parameter.
Gets a handle to an hwIFont interface for the font of the legend.
Gets the leader position for the legend.
Gets whether the legend is displayed or hidden.
Sets the various attributes of the legend to the default settings.
Sets the border thickness of the legend.
Sets the legend border to the specified color.
Sets the leader position for the legend.
Sets the position of the legend.
Sets whether the legend is displayed or hidden.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
