pltIMacro SetComplexNotePositionInROP
Sets the position of the complex macro note.
pltIMacro_handle SetComplexNoteAttachPtInROP in_rop
Tcl Modify
This command sets the position of the complex macro note (in the real/phase plot or the imaginary/magnitude plot). This function only works if there is a complex macro with a note.
- in_rop
            - true
- If you want the complex macro to be in the real or phase plot (depending on what kind of plot it is set to).
- false
- If you want the complex macro to be in the imaginary or magnitude plot.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetMacroHandle mc 1;
mc SetComplexNotePositionInROP true;
mc Apply original false;Errors
Keywords
Tcl
Complex Plot
Macro
Note
Modify
