pltINote DrawOutline
Draws an outline around a note.
pltINote_handle DrawOutline
Tcl Modify
This command draws an outline around the note if there is not one already. If there is an outline, this command removes the outline.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetNoteHandle n1 1;
n1 DrawOutline;
Keywords
Tcl
Note
Modify
Create
