pltIStatisticsTemplate SetEditable
Sets the statistics template to be editable or not.
pltIStatisticsTemplate_handle SetEditable editable
Tcl Modify
This command sets the statistics template to be editable or not.
- editable
- The input for the editable variable is a true or false value. - True
- Sets the statistics template to be editable.
- false
- Does not allow you to edit the statistics template.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetStatisticsTemplateHandle st 2;
st SetEditable true;Errors
Success (a true or false value) or an error message is returned.
Keywords
Tcl
Statistics
Template
Modify
