poIAssembly GetLabel
Gets the assembly label.
poIAssembly_handle GetLabel
HyperView Tcl Query
This command retrieves the assembly label.
Error
Returns a valid non-zero value if successful, otherwise an error code.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets the assembly ID.
Gets the visibility state of the assembly ID.
Gets a handle to the parent assembly.
Gets the ID of the parent assembly of an assembly.
Gets an iterator handle used to cycle through all of the parts of an assembly.
Gets the pool name in which the assembly exists.
Gets an iterator handle used to cycle through all of the sub-assemblies of an assembly.
Gets the visibility state of an assembly.
Sets the display state of the assembly ID (on or off).
Sets the assembly label.
Sets/changes the parent of an assembly to a different parent ID.
Sets the visibility state of an assembly.
HyperView Tcl Query
