poICollisionSet SetProximity
Sets the proximity value.
poICollisionSet_handle SetProximity
HyperView Tcl Modify
This command sets the proximity value.
Error
Returns 0 if successful, otherwise an error code.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Adds selected entities to be used by the collision control.
Returns the event which triggers animation stop.
Returns the binding: part, element, or node.
Returns the proximity state.
Returns the collision set ID.
Returns the collision set label.
Returns the proximity value.
Returns a selection list for a given group.
Removes the selected entities.
Clears all selection sets.
Sets the event which triggers animation stop.
Sets the binding: part, element, or node.
Sets the proximity state.
Sets the collision set label.
ON THIS PAGE
ON THIS PAGE
