poIContourCtrl GetIgnoredFlippedNormal
Gets the state of the "Ignore Flipped Normal" option set for the feature angle average.
contour_handle GetIgnoreFlippedNormal
HyperView Tcl Query
This command returns the state of the "Ignore Flipped Normal" option set for the feature angle average.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Get the Ignore Flipped Normal state
if {[contour_handle GetFeatureAngleAverageEnableState] == true  } {
set flipped_normal [contour_handle GetIgnoreFlippedNormal]
hwi CloseStackError
Returns a Boolean value (True or False).
