poICrossSectionSet GetType
Gets the type of cross section.
poICrossSectionSet_handle GetType
HyperView Tcl Query
This command retrieves the type of cross section.
Returns zero.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets the entity set information of the cross section for a given entity type.
Gets the cross section ID.
Gets the IType value of the cross section.
Gets the ITypeID value of the cross section.
Gets the cross section label.
Gets the cross section visibility state.
Sets the cross section visibility.
ON THIS PAGE
HyperView Tcl Query
Returns zero.
ON THIS PAGE
