poIFLDCtrl GetLooseMetalLineOn
Gets the curve definition mode.
poIFLDCtrl_handle GetLooseMetalLineOn
HyperView Tcl Query
This command retrieves the curve definition mode.
Returns file, math, or value curve mode.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Adds a study case.
Gets the ID of the active study case.
Gets the color of a particular band of the FLD zone category legend.
Gets the label of a particular band of the FLD zone category legend.
Gets the study case control object for FLD.
Gets a list of study cases.
Gets the current contour type of FLD.
Gets the auto load/unload FLD data state.
Gets the legend control object for FLD.
Gets the ID of the plot window.
Removes a study case.
Sets the active study case.
Sets the color of a particular band of the FLD zone category legend.
Sets the label of a particular band of the FLD zone category legend.
Sets the curve definition mode.
Sets the FLD contour type.
Sets the auto load/unload FLD data state.
HyperView Tcl Query
