poIPostManager GetNumberOfReaders
Gets the number of readers.
poIPostManager_handle GetNumberOfReaders
HyperView Tcl Query
This command retrieves the number of readers.
Returns the number of readers.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Adds a material that describes the graphical properties of a surface, such as shininess, emmissivity, and specular color.
Loads the given model file. A reference to the model needs to be attached to a post client window using AddModelReference.
Query whether the HyperView - MultiCore (previously known as Upfront Data Loading Mode) is enabled or not.
Gets the list of fonts available on a machine.
Gets the global property list.
Gets the global property type.
Gets the global property value.
Gets the list of values for the global property value.
Gets a handle to a graphic material.
Gets a list of graphic materials.
Gets the maximum percentage of physical memory that the post client should use.
Query whether the memory usage warning is enabled.
Gets the memory warning threshold value.
Gets a list of filters for all model readers.
Gets a list of all loaded models.
Gets a list of model readers for a given model file. If no filename is given, then all model readers are returned.
Gets a list of post (or window) references to the given model.
Gets the action associated with the given button modifier key string.
Gets a description of a mouse button function.
Gets the list of available mouse button actions.
Gets the list of properties for the specified reader.
Gets the property type {NUMBER, STRING, LIST} for the specified reader.
Gets the property value for the specified reader.
Gets a range of valid values for a particular property of the specified reader.
Gets the handle to the global graphics rendering options.
Gets a list of filters for all result readers.
Gets a list of result readers for a given result file. If no filename is given, then all result readers are returned.
Determines whether the given file is supported in HyperView - MultiCore profile.
Looks through the list of enumerated fonts to see if there is one that matches the passed attributes.
Query whether any HyperView window is loading data of the given type.
Removes a material from the material's list.
Removes the given model from the master model table. The model is only removed if there are no other references to that model.
Restores the mouse actions to the defaults.
Enables or disables disk caching.
Sets the default values to the global properties.
Sets the global property value.
Sets the maximum percentage of physical memory that the post client should use.
Enable or disables the memory usage warning.
Sets the memory warning threshold value.
Sets the given button and modifier key string to the action.
Sets the pool aliases for pool reference resolution.
Sets the property value for the specified reader.
Causes the application to wait for all of the results of the given type to load before returning.
ON THIS PAGE
HyperView Tcl Query
ON THIS PAGE
