poIQueryCtrl GetIteratorHandle
Creates and returns a handle to the QueryIterator object that allows you to iterate through query results.
poIQueryCtrl_handle GetIteratorHandle name
HyperView Tcl Query
- name
- The name of the iterator handle.
proc QueryData {model selection query_string {output stdout}} {
    # get query control handle
    $model GetQueryCtrlHandle Query1
    # set query parameters
    Query1 SetQuery $query_string
    Query1 SetSelectionSet [$selection GetID]
    # query
    Query1 GetIteratorHandle iter1
    # output data ...........................
    if { $output == "stdout" } {
  # output to console
	while { [iter1 Valid] }
	    puts [iter1 GetDataList]
     iter1 Next
    } else {
  # output to user-defined stream
  Query1 WriteData $output
    # cleanup
    iter1 ReleaseHandle
    Query1 ReleaseHandle
}Errors
Returns 0 if successful, otherwise an error code (HW_Error).
