poIQueryExpressionRule GetExpression
Gets the query expression rule type from the advanced query.
rule_handle GetExpression
HyperView Tcl Query
This command is used to get the expression query rule from the advanced query.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule expression]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExpression "<= 200"
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the advanced query handle does not exist anymore.
