poIQueryExtremeRule GetExtreme
Gets the query extreme rule type from the advanced query.
rule_handle GetExtreme
HyperView Tcl Query
This command is used to get the extreme query rule type from the advanced query.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "BottomN 4"
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the advanced query handle does not exist anymore.
