poIQueryRule GetLabel
Gets the label from the query rule.
queryRule_handle GetLabel
HyperView Tcl Query
This command gets the label from the query rule.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule mindist]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetLabel distanceRule
rule_handle GetLabel
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the query rule handle does not exist anymore.
