poIQuerySetRule GetSelectionSetHandle
Gets the selection set handle.
rule_handle GetSelectionSetHandle
HyperView Tcl Query
This command gets the selection set handle from the advanced query.
hwi OpenStack
hwi GetActiveClientHandle client
clientGetModelHandle model_handle 1
set ruleID [client AddQueryRule selectionset]
client GetQueryRuleHandle rule_handle $ruleID
set setID [model_handle AddSelectionSet node]
model_handle GetSelectionSetHandle selectionSet_handle setID
selectionSet_handle Add "id 100-150"
rule_handle SetSelectionSet [selectionSet_handle GetID]
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the advanced query rule handle does not exist anymore.
