poIResultMathCtrl SetSubcase
Sets the subcase ID in which the user-defined data type will be created.
rmathexp_handle SetSubcase subid
HyperView Tcl Modify
This command sets the subcase ID in which the data type will be created.
- subid
- The ID of the subcase. A value of zero means that the data type will be created in all of the subcases.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set eid [rmath_handle AddExpression]
rmath_handle GetExpressionHandle exp_handle $eid
exp_handle SetEquation {T1+2} alias      # alias form
exp_handle SetSubcase 1
exp_handle Commit
hwi CloseStackErrors
None.
