poISection AlignView
Align view from the normal direction of a planar section.
poISection_handle AlignView
HyperView Tcl Modify
This command changes the view to be aligned with the normal direction of the planar section cut.
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle post_handle
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# Align View
section_handle AlignView
hwi CloseStackErrors
None.
