poITracingCtrl GetColor
Gets the node trace line color.
poITracingCtrl_handle GetColor
HyperView Tcl Query
This command retrieves the node trace line color.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Adds a live link tracing curve for a single node over frames to the selected window.
Adds a live link single curve of all tracing nodes to the selected window.
Adds an entity to the tracing control.
Adds a node to the tracing control.
Adds a part to the tracing control.
Adds a simulation step index to the list of simulation steps that are traced.
Adds a static tracing curve for a single node over frames to the selected window.
Adds a static tracing curve for a single node over frames to the preview window.
Adds a single curve of all tracing nodes to the selected window.
Adds a static single curve of all tracing nodes to the preview window.
Gets the base time of the line tracing.
Gets the entity color.
Gets the list of node's that are being traced.
Gets the available entity types.
Gets the list of nodes that are being used for line tracing.
Gets the node trace line thickness.
Gets the node trace mode.
Gets the valid list node/component trace modes.
Gets the list of nodes that are being traced.
Gets the number of entities of the given type.
Gets the node trace number of steps.
Gets the list of part IDs that are being traced.
Gets the list of simulation traced steps.
Removes an entity from the tracing control.
Removes a node from the tracing control.
Removes a part from the tracing control.
Removes a simulation step index from the list of simulation steps that are traced.
Sets the node trace line color.
Defines the Tracing plot 'Color by Component' option.
Defines the Tracing plot 'Curve by Component' option.
Sets the entity color.
Sets the node trace line thickness.
Sets the node trace mode.
Sets the number of traced steps.
Sorts nodes of the Tracing panel based on certain rules.
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
