poIVectorCtrl SetScaleMode
Sets the scale mode used to display vectors.
poIVectorCtrl_handle SetScaleMode name
HyperView Tcl Modify
This command sets the scale mode used to display vectors.
- name
            - magnitude
- Display vectors by their magnitude.
- uniform
- Display vectors using a uniform size.
Returns 0 if successful, otherwise an error code.
