tblITableEditor GetFilledTableSize
Returns a list of filled rows and columns.
tblITableEditor_handle GetFilledTableSize
Tcl Query
Returns a list of filled rows and columns. The first value of the list is the number of rows between the top and bottom row which contain cell values, the second value is the number of columns between the most left and right column which contain cell values.
$filledSizeList will be {5
        4}.set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set filledSizeList [$activetableHandle GetFilledTableSize]Errors
