txtITextEditor GetEvaluatedText
Returns the evaluated text.
txtITextEditor_handle GetEvaluatedText
Tcl Query
Returns a string indicating the evaluated text.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Clears the text editor.
Redraws the text editor.
Evaluates the raw text.
Returns the background color.
Returns the evaluation state of text client text.
Gets a handle to the font.
Returns the foreground color.
Returns the name of the text file.
Returns the raw (unevaluated) text.
Loads the text from a file.
Refreshes all page areas with the text changes that have been made.
Saves the content of the text editor to a file.
Sets the background color.
Allows you to control the evaluation state of text client text.
Sets the foreground color.
Sets the raw (unevaulated) text.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
