vidIViewControl M1
Memorizes the current view of the video.
hwIViewControl_handle M1
Tcl Modify
This command memorizes the current view of the video window (including the exact axes dimensions). If you want to return to this view later, can call the R1 function. The M2 and R2 functions work similarly.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc;
vc M1Errors
Returns success (0) or an error code.
Keywords
- Tcl
- Video
- Modify
