1D
Explore the different types of 1D mesh you can create in HyperMesh.
Models are typically meshed automatically, but individual elements can also be modified manually to improve element quality in problem areas.
Meshing is organized by the type of mesh operation involved.
  • Min Size 1D: the elements that have a length less than the value specified are highlighted when the length function is selected. These elements remain highlighted until you exit the tool or you select another check element function.
  • Max Size 1D: the elements that have a length greater than the value specified are highlighted when the length function is selected. These elements remain highlighted until you exit the tool or you select another check element function.
