Tracing
Trace key points and objects in your video and set up a tracking system on an object in the video.
View new features for Altair HyperWorks 2023.1.
The user interface provides you with a consistent look and feel when you are working in any application.
Apply annotations, headers, and footers to your video.
Compare video frames or overlay frames with other videos or images to watch them in flips.
ON THIS PAGE
ON THIS PAGE
