Create Gauge Inputs
Use the Gauge tool to create design variables based on the thickness of selected properties.
From the Design Explorer ribbon, click the Gauge
tool.
Select properties.
Gauge input values can be entered in one of the following ways:
- As a continuous range of values, where the lower and upper bounds are specified as a percentage plus or minus its nominal value.
- As a continuous range of values, where the lower and upper bounds are specified specifically.
- As a list of discrete values.
In the microdialog,
- Select how you would like to define the input values, then either specify the lower and upper bounds or specify a list of valid discrete values.
- Click Create.
