TEMP
Specifies the location to create temporary files.
TEMP directory
- directory
- The path to the directory.
Examples
To set the directory to /tmp: TEMP /tmp.
None.
View new features for Altair HyperWorks 2023.1.
Learn how to start applications on Windows and Linux.
HyperMesh Batch is a non-graphical version of HyperMesh that can be used to run command files or Tcl scripts in batch mode.
The start-in directory is the location from which the application is launched.
Settings files include command<#>.tcl and hwsettings.xml.
There are various types of startup customizations that are possible. These items define how the application looks or behaves at product startup.
HyperMesh allows you to create a script file named hmcustom.tcl that can be used to automatically execute a series of commands or to define custom settings during startup.
Environment variables can be defined to configure various aspects of the application.
Sets path to a cache location for speedier invoke launch times for a server to client setup.
Defines PAM-CRASH ERF-format behavior in HyperGraph.
Defines how LS-DYNA ASCII and binout requests are presented in HyperGraph.
Sets the default file type displayed in the file browser.
Sets the location to read/write the command file.
Sets the mode to write the command file.
Displays the graphics rotation frame rate in the command window.
Forces HyperMesh batch to use stubbed-out graphics libraries on Linux.
Allows a component to be part of more than one assembly.
Sets the location to read/write the hwsettings.xml file.
Creates a file that contains HyperMesh startup timing information.
Specifies the path to search for certain configuration files.
Controls the display of the application's build number on the application title bar.
Specifies the UG license server to use for versions 9.0 and later.
Specifies additional paths for searching for Tcl scripts.
Specifies the path to the UG installation directory for importing UG files.
Specifies the path to the UG installation bin/UGII directory for importing UG files.
Specifies the UG license bundle to use for importing UG files.
Specifies the UG license server to use for versions 8.5 and earlier.
Controls the new visuals created by the Composite extension on Linux platforms.
HyperMesh has a configuration file named hm.cfg, which is read on startup and is located in the <install_directory>/hw/bin/<platform> directory.
A preference file is an ASCII file that configures the application or its clients. It specifies default user settings, such as the order in which colors are assigned, the default printer and default page layout.
A session file is an ASCII text file that contains a structured list of session statements.
Report templates are ASCII text files that contain statements for creating reports.
ON THIS PAGE
TEMP directory
Framework Environment Variable
None.
ON THIS PAGE
