Convert the Current Horizontal or Vertical Axis Unit of Measure in HyperGraph 2D
                Right-click on the horizontal or vertical axis in HyperGraph.
                The HyperGraph context sensitive menu is displayed.
                From the HyperGraph context sensitive menu,
                        select Convert Units.
                The Convert Axis Units dialog is displayed. The unit of measure category for the axis you selected is automatically selected on the Convert Axis Units dialog. For instance, if you selected the horizontal axis and the unit of measure is meters, Distance will be selected on the Convert Axis Unit dialog.
 - From one of the drop-down menus, select the new unit of measure to which you want to convert the chosen axis.
                Click OK.
                The axis unit of measure is updated accordingly.
